On recordings and when switching channel info bar with hdmi source will not go, there is no option to turn off info bar, would really appreciate some help! Very annoying!
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
Hi, yeah firmware is up to date, I sorted the original issues by going through an auto start up as suggested on a forum but now when a program goes to an advert or come back from advert the info bar comes on again for 10 seconds or so! Very annoying again
@Edhall13 wrote:Hi, yeah firmware is up to date, I sorted the original issues by going through an auto start up as suggested on a forum but now when a program goes to an advert or come back from advert the info bar comes on again for 10 seconds or so! Very annoying again
Hi @Edhall13
This is a well known fault which Sony appear to not have any clue how to fix it. It is now existed for two years. It normally appears every time the audio format changes or switches. The work-a-round is to turn off the info bar completely. Home -> Settings-> Channel setup -> Info banner -> Off.
I don’t have that menu on my tv unfortunately, model is KD49XF759
thanks for your time
That is all I have on channel setup, yes it is android tv
Hi @Edhall13
I haven't seen a setup display like yours. It may be because I have a KD-55XE9305. What version of Android do you have and if possible can you display the TV About screen.
Apologies for late reply, this is the only software version page I can find
