Hi guys is there any tips on getting this working . none of my HDMI ports will work . then one day they will then for two or three days the dont its on continus cycle its doing my head in the tv is onlt 3 months old . Ive tried everything replaced cables tried one thing at a time etc etc really getting fed up with it. Its not as if it was cheap it 2100 pound any one any ideas or would i be as well sending it back to currys
Also i may ad ive already replaced a skyhd box thinking it was faulty . And know the same has happend to this i dont think its the sky boxs . PC will work no xbox one no now tv no sky hd fed up the back teeth with it
Hi there
Before I pass this onto Sony support and they would get you to do this anyhow...
Have you noticed if there is any pattern on when it fails? Such as a certain time of day or..?
The HDMI cables you purchased, are they of sufficiant quality? I mean, do they have any type of shielding?
