I have the above two products and have been working in sync for last 6 months. Recently (last 1-2 weeks) the sound bar wont turn on with the tv, the tv remote wont control the volume either. Also the tv used to turn on automatically when a device (Sky or XBOX One) was turned on. But that has stopped working to. I have tried different HDMI cables which makes no difference. Rebooted the tv multiple times.
What should I try next? Getting highly frustrated with it.
James
It could be sky that is messing up with HDMI-CEC features. Try disconnecting it and resync your braviasync device list. If it works fine, you could start thinking connecting sky via an HDMI cecless cable/adapter
It's the Sky Q 2tb box, would that still cause an issue?
Did you try to turn off and unplug your TV & soundbar ?
Me have issue with Bravia sync & CT790 sometime and hard reset of soundbar can fix this.
