I've had this TV a while now, the sound will intermittently cut in and out some times it will do this for about 10 minutes or all day.
It's very frustrating and I cannot get it to stop. After spending the amount I did on this TV it's a bit disappointing to have this happen.
Sometimes as well the backlight will also flicker, between bright and dull before settling back down to normal.
Can anyone help with this?
Can anyone help please?
Hi there
The first two steps in the troubleshooting process is:
If the factory reset doesnt resolve the sound cutting out issue - do you have an external audio system like a soundbar or AV Receiver? or are you using the TVs internal speakers?
In regards to the backlight flickering etc - can you try turning OFF (or set to LOW), the following two picture settings in the advanced area and see if it makes any difference:
It's got the latest android update, is that what you're meaning by firmware?
I have a Sony sound bar attached via optical cable.
Hi there
To check if you are on the lastest firmware:
Also, try setting the "Digital Audio Out" to "PCM" in the TVs sound settings.
If that fails to resolve it, try a factory reset, as mentioned above.
I've got the latest firmware.
I've done factory reset in the past and the issue persists.
Digital audio out is already set to pcm.
I'm currently running the TV without the soundbar to see if it occurs still or not.
