x
KD-65AG9 external HDD still ON
profile.country.SK.title
ruzicka851
Explorer
Hi, my ext. HDD drive remains permanently ON even when the TV s in stand-by. Is this normal behavior?
This is my first Sony TV and this was certainly not the case with other TV brands I had before.
Thanks for any suggestions.
3 REPLIES 3
profile.country.GB.title
Joe_Dohn
Specialist
Android TV has 2 standby states, one that is powered and another that is true standby. It remaining on is due to the TV switching between those two states, it's not unique to Sony TVs though, it's an Android TV-level function and is perfectly normal behaviour.
Hope this helps!
- JD
ruzicka851
Explorer
Thanks for clarification. Can I force the true stand-by mode? I had the TV on Power in stand by for few days already and it IT never entered the true stand-by, so the HDD keeps spinning.
Thanks
HannahEd01
Community Team
Hi ruzicka851, there's no option to force true stand-by. If you're concerned, you might consider powering it off from the mains.
