x
profile.country.GB.title
cullums63
Explorer
KD-65A1
My TV has ceased responding to any HDMI inputs and instead displays the Android home screen at all times
I have a Sat TV box connected to HDM1 2 via an Anthem MRX510 amp and a OPPO UDP-203 Blu-ray player connected directly to HDMI 3
I can see the inputs are selected via the TV inputs settings and hear the sound coming from the amp but only Android is displayed
TV has the latest updates
I have changed nothing at all - the setup had worked flawlessly for several years
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.IT.title
Marino.Manolo
Genius
So... Before contact a Service Repair you can try a Factory Reset...
3 REPLIES 3
Marino.Manolo
Genius
Try to reboot Android TV, keep pressed Power/OFF on remote.
cullums63
Explorer
No change
Marino.Manolo
Genius
