Hi All
I have a few questions relating to Freeview and recording:-
Unfortunately it is stated since 2015 that if you activate youview you won't have the recording features
How disappointing for a 2019 tv.
I'll switch to Freeview for now (which similarly would be better if this could be upgraded to Freeview Play)
Have I got this right...
You can have catchup with the Spony built in YouView but not recording
Or you can have recording with Sony built in Freeview HD but not catch up
You can't have both (which are available if you bought a Youview box or a Freeview Play box)
You can have also most of the catch up without youview, you may find plenty of thread of which app are available (i.e. BBC Iplayer) or can be sideloaded outside of youview.
Keep in mind that no other tv (afaik) offer youview inside the tv itself....
Can you add Freeview Play on the TV as this does catch up, recording (whilst you watch a different channel) and series link. A lot more than the built in Freeview HD
Thanks, Phil
Sorry I don't get your last message also because in Italy we don't have something similar to your freeview system...
In any case with an XG95 you CAN record a program while watching another having a twin tuner...
