All favorit channels dissapeared suddenly! Software version PKG3.533.0108EUB.
Work around was: Get and adjust those channels again and those was working again! The Program Guide is also emty after this failure, so usb recording is really difficult!
Markku
Hi there
I am unsure if you have managed to resolve your issue with the work-around you posted, or do you still require help?
Yes, i made few softboot and after these guide started to work like before, flickering few times and no sound until 30 seconds!
The Sony Support gave some advices like softboot. These kind of failures are something I did not expect from Sony!
Markku
