I am unable to use any of the HDMI ports on my Sony Bravia KD-55X8509C and also unable to get anything through the digital tv. I have tried resetting the TV several times, unplugging for 30 seconds etc., but nothing seems to work. The 'troubleshooting' on the TV itself is absolutely useless.
Apps appear to be working - YouTube, Netflix, Amazon.
Anyone have this problem, or know of a resolution?
Thanks
Hi Nick,
Welcome to the community.
Has your KD-55X8509C got the latest firmware installed?
Thanks,
Pascale
I have the same issue. I have a 49XD9005 with the latest firmware. Hard reset have not solved.
Have you solved?
Was there ever a fix found for this issue?
Thanks
Reece
