Hi, I have this TV set and new features (at least in my region) seem to be buggy:
Are these known issues? Could someone confirm? I could not find similar issues with the search engine.
Thanaks a lot!
Nadav
Thanks Nadav.
I have passed the first item you shared onto the technical team for further investigation.
I've checked the second item for you and this is expected behaviour I'm afraid. When leaving a channel and returning later, the default audio channel will be used.
Cheers,
C
Thanks for your reply! Perhaps the second issue should be addressed by the technical team of this channel... Waiting with anticipation for answer regarding the fisrt issue!
Cheers, N.
