- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My KD-49XG9005 doesn't control my Panasonic SC-HTB258 Home Cinema speakers anymore, it's connected to HDMI port 3 (ARC).
If I select Audio System in Settings and use the Panasonic remote for volume it still works but the Sony remote won't control the volume like it used to and I have to turn the Panasonic on and off separately now.
I've not knowingly changed anything, it just stopped working.
I've tried turning on HDMI Control (CEC) using the Bravia Sync Settings but when I try the Sony says "No HDMI devices found. Please check the connections.
Has anyone else had this problem, and can it be fixed?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try to restart Android TV, hold the Power/OFF button.
Also try to disconnect and reconnect the HDMI Cable, and maybe change it if you can.
At the limit there is also the restoration of the Factory Settings, but it also applies to the Soundbar.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
loath to do a full factory reset as I spent hours getting the image to
look good.
I was wondering does the HDMI control and ARC require a special HDMI cable?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
"I've already done the re-start procedure, but that didn't help, I'm
look good."
I know, but if you can't solve it in any other way, all you have to do is try.
"I was wondering does the HDMI control and ARC require a special HDMI cable?"
At least HDMI 1.2a for CEC
At least HDMI 1.4 for ARC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
telling what the cable spec is by looking at one?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Difficult without the packaging, but with 1.2a and 1.4 we are talking about older Versions, I imagine that yours are more recent and therefore also include other Specifications.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My cables all say HDMI plus ethernet.
I've just swapped to a different cable but that didn't work, but then I turned off everything (TV, Soundbar, Humax HDR, Zgemma Enigma2 satellite receiver) and it now works perfectly.
All devices show up in the Sync settings list and the soundbar is operating exactly as it did a couple of days ago.
So the usual turn it off and back on again has worked, but had to be applied to ALL connected devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sometimes I take some procedures for granted, in fact I could have added the suggestion about restarting the Soundbar 🤗
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Absolutely NO PROBLEM 😊
I was already turning the TV and soundbar on and off with each step I took to try and fix the problem.
I had no idea that turning off the other devices connected to the TV might help, but I definitely know now.
Turn it ALL off and back on again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Strictly, you shouldn’t expect HDMI connections newly made between two pieces of kit to work if both are already turned on.
They often will, because they are fairly tolerant of us humans.
But if you get into any difficulties, power down everything, power up the sink devices first, and then power up the source devices, letting each one settle.
The most ‘sink’ of all your devices will be the soundbar. The TV will be the source device for this, and should be powered on next, as it is the sink device for all the equipment plugged into its other HDMI ports.
(If you have one of those soundbars with an HDMI input, then the soundbar is still the sink device, and the device plugged into it is a source device, but the TV is now the sink device and the soundbar the source device for the video from the device plugged into the sound bar. This little anomaly is something that the soundbar and the TV will work out for themselves as part of the ARC/eARC convention, which is why powering on the soundbar last, instead of first, will still work OK 😛)
