Hi guys,
Any known issues with this set and Sky Q, specifically waking/sleeping the TV with the Sky Q remote.
I think I've sorted the waking up side of things via Bravia Sync but when I try to switch the TV off with my Sky remote I get an Android TV prompt for "Power Off" or "Restart" I believe.
Any ideas?
Hi @slipd83 You are holding down the Sky Q remote power button too long. Hold it down for only 2-3 seconds. The latest Sky Q remotes flash when the TV turn off command is sent.
Yes! Nice one - sorted.
Thank you.
