x
profile.country.GB.title
KEGWEG
Explorer
ITV Hub
How do I find ITV hub
1 ACCEPTED SOLUTION
Accepted Solutions
KEGWEG
Explorer
4 REPLIES 4
LightFoot
Specialist
Hi @KEGWEG   Generic answer as you have not told us which model you are referring to? Make sure YouView is enabled and then look in Sony Select.
KEGWEG
Explorer
Thanks for your reply
Model is
Sony KD-43XH8096,
Excuse my ignorance but where do I find "Sony Select"
LightFoot
Specialist
Hi @KEGWEG   In Apps or on the Home page. It is normally green with Sony Select in white. It is just a normal App like Netflix, prime video etc.
KEGWEG
Explorer
Solved  Thamks
