I've read a lot on various forums but I haven't found a solution to this.
When I try to use ITV Hub I can usually get to the first set of adverts but then the playback just stops. If I try and stop and then resume from where I left off I get the privilage of watching the adverts again but it doesn't get to the programme.
This is only on my Sony Bravia KD-49X8305C. I can watch online or on a firestick without issue. My TV is up to date with firmware V5.433. My ISP is Vodafone. I tried watching through a VPN but that didn't work either.
I used to have the same problem with All4 but it seemed to get resolved with a software update.
Are there any fixes here? Its very frustrating as I get this TV for its 'Smart' features and figured that an Adroid would be a good bet but I've never not had issues like these.
Thanks for the replies and suggestions. I've tried most of them (not a full reset) and it doesn't work so I've given up and have opted for a kodi addon. Not what I would choose but at least it works for the rare occasion I want it.
also have same problem but cannot find a solution, sony absolutely no help at all. wont ever buy a sony tv again and will advise anyone else not to buy one. total crap
I have the same model and experience similar problems. Most often i get half way through a program and after an advert break, the program starts from the begining again.. so annoying and the only way to get round it is to fast forward until just after the advert break..
Mostly i fix these little issues by forcing a soft reboot (press+hold power button on the remote).
I've never had to do a factory reset. any problems i have come across are usually resolved by the reboot.
thank you for all the suggestions however i have tried everything plus a factory reset and nothing resolved the problem so i too like Mr-PEZ have given up until Sony can come up with a fix as it is clearly an issue with YouView and this model TV. ITV HUB on my Panasonic TV and Freeview no problems whatsoever !
Does Youview actually even ever get updated on the Sony TVs anymore? Not heard anything for a long time about it.
You could try posting over on the Youview community, https://community.youview.com/youview/
YouView forum gives the answer!
Re-do the initial set up, and consent to all when asked.
Worked for me after a very frustrating afternoon! I’m a bit annoyed that Sony effectively control what I consent to though!
Not worked for me. Gave up. Sony you need to have pride in your product and fix the problem.
I have 5 Sony TVs and they are all doing the same thing. Updates all applied.
A new Sony Bravia KDL32WE613, purchased mid November 2019. All worked beautifully till one week ago, when the ITV Hub stopped working after the first set of adverts. I have tried everything suggested in this topic with no success, and frankly am both frustrated and disgusted. When is Sony going to do something about what appears to be a very common problem?
