I'm looking for a new tv that's good for both watching movies and gaming (low input lag). For these two reasons i've narrowed it down to the "Sony KDL-42W705B ". Unfortunately this model don't come in bigger sizes, i want atleast a 46". However there is a model called "KDL-48W705C" (check link below). Is the W705C the same model as the W705B, if not..what's the difference between these two?
https://www.sony.se/support/sv/product/KDL-48W705C
Thanks in advance /Izak80
Hi there
In general, theres not a lot between the two, both TVs have MotionFlow XR 200 for example.
However the W705C is a 2015 model, whereas the W705B is a 2014 model. The W705C has the option to plug in an external subwoofer as an option accessory as well.
I took a longshot and sent an mail to the Sony Support and they sais the same thing: W705C i a 2015 model while the W705B is from 2014. What i don't get though is if the W705C is the 2015 follow up to W705B or if it's more like the follow up to the W605B.
Thanks for your quick reply
Isak
