- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
May 2019
May 2019
IR Balster on kd 43xf8596
When trying to configure the IR blaster usung the initial setup wizard on kd 43xf8596, I get the message An error has occured. Please try again later.
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2019
May 2019
Hi Josh,
I'm just going to try to find this out for you, but in the meantime, maybe someone else in the community might be able to assist.
Thanks,
Pascale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2019
May 2019
correction the model is 8796
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2019
May 2019
Hi josh2019,
I believe this could be a connectivity problem. Make sure you're setting up everything correctly. You'll find a full Guide on this setup here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-43xf8796/artic...
Let us know if you still face the same problem.
Cheers,
Vanilla
