Hi
Has anyone experienced same issue that the internal android keyboard will not open. I have tried to change the setting system preferences without success, seems to developed fault since the last update. Thanks
Manolo
Hi
Thanks for the reply, no I have never had an external keyboard attached, but just took out a usb receiver for a mouse and that has fixed the problem. Thanks a lot for your help, as i was getting no where with it!
