Hi, me again.
so, iv'e got this Sony KD55XD7005, i was happy with it, but it had some real bad DSE, so iv'e called sony, it been replaced.
the second one had bad light leak, replaced again.
https://community.sony.co.uk/t5/android-tv/kd55xd7005-light-leak-problem/m-p/2289601#M15841
now the third is the WORST! some real ugly pink/ purpule/red Hue that is even visible in bright scene, called sony, a technician came and said he sees it but he thinks that the TV wont be replaced again.
now i'm wating for the replay.
my question is: is this model is Faulty? should i demand a refund?
thank you for any answer...
P.S all 3 TVs were manufactured on the same month 11/16
Hi there
I am unsure if you are just super unlucky, super picky or whether there is a higher fault rate with this model.
As you are aware, DSE is a general issue with LCD technology. Some panels are better/worse than others. I have not come across many complaints with this model in regards to DSE on either the Sony Community Forums or AV Forums - so if there was a major underlining issue which quality control on this model, then I would expect a lot more complaints on these forums....
My money is on : you have been super unlucky !
