I have now successfully paired Bravia Cam with my XR-55A95K TV. I have set Proximity control but have no idea how to make Gesture Control work. Can someone help?
Hi @jprice126 That is an easy one to answer, gesture control has not been added to the software yet 😂
Just Auto adjusts picture and sound and Proximity alert at present. Knowing Sony we will probably get it in 2024.
Hi @jprice126 Google Meet (I’m sure there are others) in the Play Store (Apps on the Home Screen). The camera resolution doesn’t look the best, especially in the darkened room that I am currently in.
@jprice126 wrote:I have now successfully paired Bravia Cam with my XR-55A95K TV. I have set Proximity control but have no idea how to make Gesture Control work. Can someone help?
Hi @jprice126 Gesture control and auto power mode (nobody in the room) added to Bravia Cam if you update your software v6.6070. 😀
Ah, that would be it then😀. I am normally good with tech but it baffled me that I couldn’t do it. Is there no video calling either?
