- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
HDMI ports on 4k
New to 4K but a little confused to which ports support 4K content ie from sky q
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi dungpooh,
As others have asked, which device are you asking about?
Many thanks,
Darran
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Darren it’s on the BRAVIA tv 55”
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks dungpooh, can you provide the model number too so we can ensure we are offering support for the correct model.
Regards,
Darran
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@dungpooh wrote:New to 4K but a little confused to which ports support 4K content ie from sky q
Hi @dungpooh
To answer your question precisely we need your TV model number (it starts with KD).
In general terms, the latest Sony 4K HDR TVs will support 4K in all 4 HDMI ports but only HDMI 2 & 3 will support 4K in enhanced mode (10 bit). However that really doesn’t matter with Sky Q as their 4K is broadcast in 8 bit. So HDMI 2 preferred leaving HDMI 3 (ARC) reserved for connecting a home theatre or Soundbar. You switch on Enhanced 4K signal format in the settings. Home -> Settings -> External inputs -> HDMI signal format -> Enhanced format.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi thanks for your reply you’ve confirmed my suspicions but is it right for the led at the bottom of the tv to be white??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your info one last issue when I switch on sky q via remote from standby the tv will switch to HDMI 2 as it should however the tv will hesitate a little before the picture appears sometime the tv will not come on at all unless the power is disconnected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @dungpooh To help you further, we will need the model number of your TV (it will start with KD-55).
