New to 4K but a little confused to which ports support 4K content ie from sky q
Hi dungpooh,
As others have asked, which device are you asking about?
Many thanks,
Darran
Hi Darren it’s on the BRAVIA tv 55”
Thanks dungpooh, can you provide the model number too so we can ensure we are offering support for the correct model.
Regards,
Darran
@dungpooh wrote:New to 4K but a little confused to which ports support 4K content ie from sky q
Hi @dungpooh
To answer your question precisely we need your TV model number (it starts with KD).
In general terms, the latest Sony 4K HDR TVs will support 4K in all 4 HDMI ports but only HDMI 2 & 3 will support 4K in enhanced mode (10 bit). However that really doesn’t matter with Sky Q as their 4K is broadcast in 8 bit. So HDMI 2 preferred leaving HDMI 3 (ARC) reserved for connecting a home theatre or Soundbar. You switch on Enhanced 4K signal format in the settings. Home -> Settings -> External inputs -> HDMI signal format -> Enhanced format.
Hi thanks for your reply you’ve confirmed my suspicions but is it right for the led at the bottom of the tv to be white??
Thanks for your info one last issue when I switch on sky q via remote from standby the tv will switch to HDMI 2 as it should however the tv will hesitate a little before the picture appears sometime the tv will not come on at all unless the power is disconnected
Hi @dungpooh To help you further, we will need the model number of your TV (it will start with KD-55).
