Got a weird bug that is causing MY 50X90S TV to have major audio delay and input lag across all apps and inputs every time the TV is restarted or comes out of sleep.
The only way I can resolve it is to head to the HDMI Signal Format setting and toggle it from Enhanced to Standard, then back to Enhanced. It does not matter which input I choose to do this, just that it gets done.
I can also temporarily fix it by quickly turning the TV off and on - it's only when it goes into the "deep sleep" after roughly 20 minutes that the problems start.
I can only conclude that the HDMI Signal Format settings are not being correctly re-initialized when the TV comes out of sleep or restarts, and my workarounds perform the necessary initialization.
I am on the latest firmware and I have performed a factory reset, but it hasn't helped.
I believe this is the root cause of the issues I have been posting about regarding this TV ever since I bought it in 2023.
I'm sorry, but I just want to have a better understanding! Is it that you have a delay in sound (lip sync), or is it no sound issue when the TV is restarted?
The lip sync is bad and there is input lag across the UI and in games.
Toggling the HDMI Signal Format settings is what resolves it.
Are you following these steps to connect the PlayStation: https://helpguide.sony.net/tv/jaep1/v1/en/04_12.html?hl=game
And I also, found this for the lip sync issue: https://helpguide.sony.net/tv/jaep1/v1/en/04-06_02.html?hl
Believe me I have tried every configuration you can think of, the only thing that helps is toggling the HDMI Signal Format. After I do that, the lipsync and input lag is pretty much perfect across all apps and devices. It's baffling.
@pabulous It will be better if you got the TV inspected by the engineers as suggested by Sony so that you don't have to keep changing the settings every time you switch the TV on.
