If I set channels as Favorite and I set the GUIDE source to Favorites, it's exiting from Favorites continuously and I see all the TV channels.
I have to re-select: Favorites in the Action menu- Favorites-Guide source menu
This problem has existed for 2 years.
Even though I posted to any forum, SONY didn't solve it .
I always select channels from GUIDE..
I have same problem. (KD-49X8309C; Model: Bravia 4K 2015; Version: 7.0; Kernel: 3.10.79; Build: 5.433 )
1. press "Action menu"
2. select "giude source"
3. select "Favorurites 2"
4. press Enter (middle of the ring with a cross)
5. press Enter on one selected program
6. select "View" and press enter
--> get a message on screen " Channel mode is Favourites 2"
Then go to Netflix or HBO GO or Video or switch to any application and return to TV (press TV button)
-> you will receive a message on the screen "Exit Favorites" (press the TV button)
This always happens when I return to TV.
Br, Tibi
Try updating to build 5.435 and see if this continues happening, not sure if it's normal (rules as mentioned earlier in the thread) or an actual issue.
