I have a Sony Bravía KD-49XF9005 TV. I have gone into the Google Play store app on the TV and cannot do anything when I'm in there! The remote suddenly stops working and I cannot navigate around the screen to look for apps. When I come out of the app, the remote works normally! Anyone know what is wrong? Thank you in anticipation.
Hi @brsteve20 Assuming that you have tried 1. a simple Reset (hold down the power button on the TV Remote until you see Power Off ..). 2. Remove everything from all the connections (HDMI, USB, Aerial etc.) and switch off. Leave it unplugged for at least 5 minutes. 3. Try a factory reset as a last resort.
Final thought, as the Google Play Store requires an internet connection, have you tried rebooting your broadband router to refresh it's DNS.
The correct way is to go to apps and press more apps, then scroll/ search for apps. Is this what you mean or have you sideloaded the regular android play store app ?
Hi - thanks so much for your detailed reply. I tried 1. and it seems to have worked, so will keep your response for future reference so I know what to do if it happens again. Many thanks for your help. Cheers.
