Has anyone managed to redeem this offer? Shows up on the Sony Select app, which tells you to open up the Google Play TV & Movies app to redeem it, but the offer isn't there. Are we waiting for an update for the TV for this to work? I have a 49XE8004.
thanks for that was a great help.
@Pascale_F wrote:Hi webby73,
Thanks for your message. We are looking into this and someone will get back to you shortly.
Thanks,
Pascale_F
I also cannot see how I can redeem this offer. There is no option called “New 4K-UHD Movie, included” to choose.
I would appreciate any help.
Thanks
Thanks, the offer has now appeared. Did you buy one of the fifteen offered or one from the normal catalogue as I can’t see any in the 15 offered at the price you said.
I'm having the same issue as the others with redemption of UHD video redemption.
i went to purchase the spider man as it was in the 4k
The solution you say?
1. Yup, had a payment method in my Google Account for years. All valid, ready to go
2. So, how do I select the movie?
3. Nope, cannot select a movie -no option to do that
4. No, cannot attempt to buy a movie as I cannot select a movie
5. Too right I'm not buying a movie - that is the only option I've got, because there are no free ones to redeem
6. Yup - where and how do I see these 15 movies to buy?
Thanks for the great help.
