Formatting a USB memory stick
SOLVED
profile.country.GB.title
stickerlee
Explorer
My new Sony Bravia ANDROID TV KD-43XD8088 is unable to format a 64 gig sandisk cruzer USB stick. I have been able to format it with a PC into default FAT32 and also its been recognised and I can format it with an Android box I have. The TV does recognise the drive is there, but after waiting a while reports can't format drive. Can anyone advise please. I have not tried any other USB as yet.
Thanks
2 ACCEPTED SOLUTIONS
Accepted Solutions
profile.country.IT.title
Marino.Manolo
Genius
you can try a Reboot of Android TV... Press hold the Power/OFF key on remote...
Manolo
Marino.Manolo
Genius
Thanks for feedback... :wink:
Manolo
3 REPLIES 3
Marino.Manolo
Genius
Manolo
stickerlee
Explorer
Many Thanks Kudos, spot on. After reboot did the trick. I chose HDD registration to record and was successful.
Marino.Manolo
Genius
Manolo
