Hi guys, I have been told I need more confirmations of this isssue. Essentially auto picture mode no longer works correctly and gets locked to last previous setting. I need some of you to test confirm so I can get submitted as an official bug with Sony.
Steps to reproduce:
Has anyone been able to fix this yet?
No matter what hdmi port I use the TV is always set to the game setting. Even using the Netflix app keeps the games picture setting.
Does latest July update fix? No internet as just moved so cannot check.
Unfortunately No
@Quinnicus wrote:Unfortunately No
Very annoying, I am assuming the next update is Android 6.0?
@Risc0n wrote:
@Quinnicus wrote:
Unfortunately No
Unless something major occurs - the next update should be Marshmallow - but there is NO ETA on this as of yet.
Thanks for confirming @Risc0n - Sony does teach one the art of patience, but it does eventually get there
for me it is quite the opposite. since MM my picture mode always goes back to standard ater the TV was in standby.
