Hi
A quick question before I have to buy a UK Sony Bravia 7......
Am I right in thinking that there is no such model as a UK 55" Sony Bravia 9?
I am aware that there may be different configurations between countries, and I dont know whether such a TV has never been produced or it is out of stock.
Can anyone give an informed authorative answer please?
Thanks.
(Dup)
There doesn’t seem to be a 9 (yet?) but there is a Bravia 8 at least, so why settle for a 7?
Thank you for the confirmation.
Appreciated.
Thanks to all the other contributers as well.
Now the only question for me is shall I get a 55" Bravia 7, or hang on until June next year just hoping that a 2025 Bravia 9 would be available in 55".....🤔
What have you got against the Bravia 8? Just curious….
Good question.
Excuse my briefness.
I recognise the better quality of the Oled models but my main criteria is to handle long periods of the TV being left on a station each day.
I'm not into hero worship of a particular technology, and I'm not jumping on any bandwagon and I'm happy to listen to good informed explanations - particularly from engineers. In particular, I am not saying Oleds are bad, far from it, just that I think the circumstances of my intended use might favour a choice of the Bravia 9 or 7 in a 55" size. Trouble is, the 9 does not come in a 55" size.
Although my opinion is influenced by different things, to give you a brief flavour or answer, I currently would mention two areas that matter that I've thought about and discussed over a long while:
PS
Sorry if I was not clear re 'OLED Organic source' LOL ....
I cant find how to correct or edit something I've just posted
If you click the little gear wheel top right on a posting you have recently made, it will include an Edit option you can use.
This option goes away once the ink on your posting has fully dried 😛
Thank you!
Appreciated
