I had to do a factory reset because home button stopped working but i cant re install ES File explorer. I used this regularly to send apps from my phone to the tv.
Can i install?
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
Just checked, all up to date
Hi Milhun,
Can you give us some more information, what is the model number of your product?
Thanks,
Ed
Hi sorry forgot the needed info.
its a KD55X8005C
had a problem with the home button not working, all sites said restore to factory to fix, which it did but now I can’t get this app onto the android side.
