Hi I have a TV button shortcut on my A90k bravia remote and it’s linked to the youview live tv and catch up, when I press it now it says “Feature not available because this app is disabled”, I have been through the settings and made sure the app is enabled and works if manually selected but it still tells me it is unable because it is disabled through the remote. The button works when ported to the other digital tv app but not youview, would really like this to be working correctly. I can possibly factory reset but would not like to set up all again leaving this message so hopefully Sony may see this because i feel it is an update issue it worked before for me but has since stopped working, thanks any recommendations will be greatly appreciated.
Tv button is now fixed thanks to an update from sony
