Hi all,
I have been looking at these two models
43XE7003BU and 42XE7002BU
I cant see to see any difference online apart from the price (about 40 quid)
I will be mainly using the TV for ps4 pro and Netflix etc
Melinda
The 7003. I looked up all the required information here.
100 Hz versus 200 Hz Motionflow.
200 Hz (if you can see the difference from 100 Hz) should theoretically be better and snappier for sport, gaming, etc.
There’s a 7073 with 400 Hz. Should theoretically be better still.
Hi - thank you for your reply. I’m confused - which one has the higher HZ?
thanks
