Sony 49xe8004
I would like to know if I can somehow jump to HDMI 1 with just a single click of a button on the remote.
Someone speculated I may be able to reconfigure the TV button or something, but I have no idea.
Can try:
From the remote,
Select Home.
Select Settings
Select External Inputs
From the options, select Customise TV Key
Select the required source, in your case HDMI 1 or whatever name has been assigned to this input.
Mick.
But be aware you can only do this on the Freeview UI. It is greyed out on the YouView UI.
Instructions for switching away from YouView, should you need them, are in the FAQ at the top of this forum.
