I've recently purchased my TV and often it is not connecting to the Internet automatically when I turn it on. Therefore the time is always off by a few minutes. Even when I connect it to my wifi manually does it not sync with the correct time. I can fix this by pulling the plug each time, but I'd rather not have to do this.
How can I force the TV not use Internet to sync time but instead use the time that is correct on my Freesat box?
I have the Sony Bravia KD65X8509CBU 4K UHD
Hi there
There is a setting on the TV to 'use broadcast time'.
Go to Settings > Date and Time > Automatic Date and Time.
Unfortunately what you are describing are a couple of known problems. See:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2130112#M41351
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2148553#M42555
