Hi all
When using YouTube or Netflix how do you check the resolution i.e. 1080i/p/2160p of what is playing? When selecting action menu the info button is not there. Is there any other way?
Hello @mobilyuk,
in YouTube you have an option in the apps settings to activate "Statistics for nerds" which will show you that info.
- Nic
To check the resolution on Netflix press the information key (I+). It displays the bandwidth and resolution being used.
