I have a Sony Bravia 55xe8396b TV bought just over a year ago and suddenly seem to be having a major issue with the WiFi on it.
Since getting the TV we've had multiple occasions where the WiFi has dropped and we've been unable to reconnect at the time, however usually a few days later the issue has sorted itself and we've been able to continue as usual. About 4 months ago, I reset the internet connection with the TV to the WPS setting and since then we've had no problems at all.
Until Thursday, I went to watch Netflix and got a message to say the TV wasn't connected to the internet. When I went back to the home screen and to the settings, I noticed the WiFi button was in the off position. I tried to turn it back on but it keeps flicking straight back to the off position.
I'm now in the process of factory resetting the TV to see if that helps, but for a TV a little over a year old, we didn't anticipate having these problems. A quick google search shows that a lot of people have issues with the internet connection on Sony TVs, so I think this might be our last one if we can't rectify the issue.
Has anyone else had this same issue or something similar? I'm not sure what else to try!
I bought a new sony tv a 65 inch one and have to re insert all the password etc of the wifi each time it disconnects and it disconnects too often especially during a film off Amazon or Disney +, I have spoken to Sony about this and they dont want to know, I have read what you say about pressing the on and off of the remote but that does not cure it, and it took me an hour the other night to get it back on, that is in the middle of a film and ruins it completely, so as good as the picture is on the Sony tv it is poor technically
Hi, yep did the update, still hasn’t cleared the issue
My problem returned with a vengeance last night.GRRRR. Every 15 mins or so an annoying notification popped up but on checking, everything connected!! Just downloaded the update recommended to USB and about to install it. Wish me luck!!
I did the update !! Still the same problem !!!!
