Hi
I am looking to buy Sony Bravia KD49XE7073. I was wondering if this has the chrome cast built in?
If not, which ones do?
Thank you very much.
Hi @Sjalan and welcome to the Community
If you have to have chromecast built in rather than buying a Chromecast dongle to attach to a TV
then you should start looking at something from the Android Bravia range, e.g. the XE80.
Hope this helps.
