Hi to all.
Sometimes on my screen ι see this icon.
Always in the same position, in the middle and right and leaves after a few minutes.
Does anyone know what it is?
Thanks!
No, It's one of those 832689 useless junk functions it has, some scanner, cleaner, whatever.........
Sadly, free version is pure bloat but at the same time probably the most UI friendly one for the TV+remote combo. You can use some other filemanger or get paid ES pro but in that case you'll also need a light theme because default dark one just does not work, some things are messed up and you can't see what you are doing.
Hi there,
Could you give us a few more details about this? What model of TV do you have? Does the Android icon appear randomly, or usually under the same circumstances?
Thanks,
Owen
Thanks to response
Τhe model is KD-49XD7005.
I see it at random times, two months ago and again twice in the last week.
I have all the latest updates.
I also attach a photo of the monitor.
Τhanks!
Yes, right!
Found the culprit!
Do you know if he wants something with this icon?
Is it a update maybe?
