I think this is a bug in the TV software.
I have the following inputs configured in "manage external inputs"
1) HDMI1 - Bluray Recorder
2) HDMI3 - WD TV box
3) AV 1 - called "Sky DVD"
everything else is hidden
problem (bug) is that the inputs menu shows "HDMI 1" twice (see screenshot) (there is an extra menu "Recorder1)" which I do not think should appear)
It would be nice if was cleared up in March 2016
PS I understand EU and UK have different firmware. odd my build says EU when I am UK
PS I know I have connected my Sky Box to a 4K TV via its scart lead so no need to point out the wisdom (lack of)
KD-49X8307C
Hi there
Thanks for posting the screenshots. Unfortunately this is a known issue with devices that use the HDMI-CEC functions (i.e Bravia Sync).
See:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2047983#M35186
Hi there
See:
Thanks for the reply. What you say seems reasonable.
and I learnt a new TLA
