I have installed via USB and tested Block This (open source) and Adguard (not together. One per time) on my KD49XD8099 with Android 6.0.1 and they simply worked great! No more annoying ads (yes, I know. Companies don't like it, especially Google, but they are perfectly legal. Also we are allowed by Android itself to install whatever we like).
The only problem is that after turning the TV off (standby) few hours, when I turn it on the television starts rebooting. Uninstalling them the television (and rebooting just in case) Android becomes "stable" again (quoted because I've got reboots even without tampering with special apps). The apps were set to enable the VPN at boot. Not that it should matter, since the reboot happens just putting the tv in standby.
Now, I do understand that an external app, not made specifically for Android TV may not work (but as I wrote they actually do the job they are made for), but if the television/Android reboots there is a (very critical) issue with the OS, not the app. To test the issue the developers just need to install the apps mentioned (again, enabling the VPN at boot).
Part 2:
05-09 22:29:51.716 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_tuner1_share
05-09 22:29:51.717 1232 1308 I GRM : ============================Start==============================
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:51.717 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.717 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.718 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.718 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:51.718 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:51.718 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.718 1232 1308 I GRM : Component Count: 9
05-09 22:29:51.718 1232 1308 I GRM : =============================End===============================
05-09 22:29:51.718 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:51.765 3543 3613 I TVAPI : TvApi CONNECTED users = 0 []
05-09 22:29:52.027 6129 6305 I chromium: [6129:6305:INFO:metrics_util.cc(106)] Metrics stat: total=2
05-09 22:29:52.027 6129 6305 I chromium: CastV2.Transport.Ping.In=24
05-09 22:29:52.027 6129 6305 I chromium: CastV2.Transport.Pong.Out=24
05-09 22:29:52.718 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:52.718 1232 1308 I GRM : ============================Start==============================
05-09 22:29:52.718 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.718 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:52.718 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:52.718 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.718 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.719 1232 1308 I GRM : Component Count: 9
05-09 22:29:52.719 1232 1308 I GRM : =============================End===============================
05-09 22:29:52.719 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_tuner0_share
05-09 22:29:52.719 1232 1308 I GRM : ============================Start==============================
05-09 22:29:52.719 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:52.720 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:52.720 1232 1308 I GRM : Component Count: 8
05-09 22:29:52.721 1232 1308 I GRM : =============================End===============================
05-09 22:29:52.721 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:53.054 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:53.060 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:53.721 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:53.721 1232 1308 I GRM : ============================Start==============================
05-09 22:29:53.721 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.721 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:53.721 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:53.721 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.721 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.721 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.721 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:53.722 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Component Count: 8
05-09 22:29:53.722 1232 1308 I GRM : =============================End===============================
05-09 22:29:53.722 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_dmx_share
05-09 22:29:53.722 1232 1308 I GRM : ============================Start==============================
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.722 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.723 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:53.723 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.723 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:53.723 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.723 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.723 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:53.723 1232 1308 I GRM : Component Count: 7
05-09 22:29:53.723 1232 1308 I GRM : =============================End===============================
05-09 22:29:53.723 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:54.492 4829 8876 W PlatformStatsUtil: Could not retrieve Usage & Diagnostics setting. Giving up.
05-09 22:29:54.723 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:54.723 1232 1308 I GRM : ============================Start==============================
05-09 22:29:54.723 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:54.724 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.724 1232 1308 I GRM : Component Count: 7
05-09 22:29:54.724 1232 1308 I GRM : =============================End===============================
05-09 22:29:54.724 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_vdec0_share
05-09 22:29:54.725 1232 1308 I GRM : ============================Start==============================
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:54.725 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:54.725 1232 1308 I GRM : Component Count: 6
05-09 22:29:54.725 1232 1308 I GRM : =============================End===============================
05-09 22:29:54.725 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:55.726 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:55.726 1232 1308 I GRM : ============================Start==============================
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.726 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:55.726 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.726 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:55.727 1232 1308 I GRM : Component Count: 6
05-09 22:29:55.727 1232 1308 I GRM : =============================End===============================
05-09 22:29:55.727 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_tvbypass
05-09 22:29:55.727 1232 1308 I GRM : ============================Start==============================
05-09 22:29:55.727 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:55.727 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:55.727 1232 1308 I GRM : Component Count: 5
05-09 22:29:55.728 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:56.704 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:56.710 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:56.728 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:56.728 1232 1308 I GRM : ============================Start==============================
05-09 22:29:56.728 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.728 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:56.728 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:56.728 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.728 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.728 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.728 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.728 1232 1308 I GRM : Component Count: 5
05-09 22:29:56.729 1232 1308 I GRM : =============================End===============================
05-09 22:29:56.729 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_rec2
05-09 22:29:56.729 1232 1308 I GRM : ============================Start==============================
05-09 22:29:56.729 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.729 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:56.729 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:56.729 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.729 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.729 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:56.729 1232 1308 I GRM : Component Count: 4
05-09 22:29:56.729 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:57.729 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:57.730 1232 1308 I GRM : ============================Start==============================
05-09 22:29:57.730 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:57.730 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:57.730 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:57.730 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:57.730 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:57.730 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:57.730 1232 1308 I GRM : Component Count: 4
05-09 22:29:57.730 1232 1308 I GRM : =============================End===============================
05-09 22:29:57.730 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_rec
05-09 22:29:57.731 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:57.731 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:57.731 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:57.731 1232 1308 I GRM : Component Count: 3
05-09 22:29:57.731 1232 1308 I GRM : =============================End===============================
05-09 22:29:57.731 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:58.731 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:58.731 1232 1308 I GRM : ============================Start==============================
05-09 22:29:58.731 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:58.731 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:58.731 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:58.731 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:58.731 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:58.732 1232 1308 I GRM : Component Count: 3
05-09 22:29:58.732 1232 1308 I GRM : =============================End===============================
05-09 22:29:58.732 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_thrd
05-09 22:29:58.732 1232 1308 I GRM : ============================Start==============================
05-09 22:29:58.732 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:58.732 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:58.732 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:58.732 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:58.732 1232 1308 I GRM : Component Count: 2
05-09 22:29:58.732 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:59.330 1716 1731 W BroadcastQueue: Timeout of broadcast BroadcastRecord{3ed413d u-1 com.sony.dtv.intent.action.PRE_SCREEN_ON} - receiver=android.os.BinderProxy@8138d32, started 10002ms ago
05-09 22:29:59.330 1716 1731 W BroadcastQueue: Receiver during timeout: ResolveInfo{c048a83 com.sony.dtv.timers/.idletvstandby.IdleTvStandByReceiver m=0x108000}
05-09 22:29:59.351 8633 8645 D QuickSetupMgrContentProvider: query()
05-09 22:29:59.353 8648 8648 I SonyDTVBrowser_WAR: receive broadcastintent PRE_SCREEN_ON
05-09 22:29:59.354 8648 8648 W SonyDTVBrowser_WAR: warn: fail sendBroadcast - PRE_SCREEN_ON
05-09 22:29:59.354 8648 8648 I SonyDTVBrowser_WAR: startWebAppRuntimeStartupService
05-09 22:29:59.357 8648 8648 I SonyDTVBrowser_WAR: onReceive end
05-09 22:29:59.363 8648 8900 I SonyDTVBrowser_WAR: onHandleIntent
05-09 22:29:59.363 8648 8900 I SonyDTVBrowser_WAR: receive intent PRE_SCREEN_ON
05-09 22:29:59.364 8648 8900 I SonyDTVBrowser_WAR: try usb load
05-09 22:29:59.370 2610 2610 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1221 android.content.ContextWrapper.startService:581 android.content.ContextWrapper.startService:581 com.sony.dtv.audiooutput.BroadcastIntentReceiver.onReceive:37 android.app.ActivityThread.handleReceiver:2725
05-09 22:29:59.372 2610 2610 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.stopService:1227 android.content.ContextWrapper.stopService:586 android.content.ContextWrapper.stopService:586 com.sony.dtv.audiooutput.BroadcastIntentReceiver.onReceive:38 android.app.ActivityThread.handleReceiver:2725
05-09 22:29:59.373 8648 8900 W SonyDTVBrowser_WAR: warn: i/o error occured : /storage/89FD-5E29
05-09 22:29:59.382 8648 8900 I SonyDTVBrowser_WAR: not hotel mode
05-09 22:29:59.382 8648 8900 I SonyDTVBrowser_WAR: send exit because fail wakeup for not found content
05-09 22:29:59.387 8648 8648 I SonyDTVBrowser_WAR: onDestroy
05-09 22:29:59.398 1716 1731 I Process : Sending signal. PID: 3064 SIG: 3
05-09 22:29:59.406 3064 3079 I art : Thread[2,tid=3079,WaitingInMainSignalCatcherLoop,Thread*=0xb7ee5f60,peer=0x12c610a0,"Signal Catcher"]: reacting to signal 3
05-09 22:29:59.597 3064 3079 I art : Wrote stack traces to '/data/anr/traces.txt'
05-09 22:29:59.601 1716 1731 I Process : Sending signal. PID: 1716 SIG: 3
05-09 22:29:59.602 1716 1721 I art : Thread[2,tid=1721,WaitingInMainSignalCatcherLoop,Thread*=0xb7ee5f60,peer=0x12c010a0,"Signal Catcher"]: reacting to signal 3
05-09 22:29:59.732 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:59.733 1232 1308 I GRM : ============================Start==============================
05-09 22:29:59.733 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:59.733 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:59.733 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:59.733 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:59.733 1232 1308 I GRM : Component Count: 2
05-09 22:29:59.733 1232 1308 I GRM : =============================End===============================
05-09 22:29:59.733 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_sub
05-09 22:29:59.733 1232 1308 I GRM : Component Count: 1
05-09 22:29:59.733 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
Sometimes the tv does not want to start at all when the vpn service is still running behind.Does it happen to you too? I have to press several times the power button before it could reboot.
By the way I have asked the OpenVPN community both nvidia shield and and meizu box do not crash. Can anyone test if setting a proxy, instead of using a vpn, will have the same effect?
I don't know. I have abandoned any test and decided to wait for 7.0. Although I have a feeling many bugs will still be there being the kernel probably the same version. Well, probably the VPN is not managed at kernel level, so it might have been fixed.
Aaand the bug is still there in Android 7.0!!!
Jecht_Sin, Thanks for the "good" news.
By the way the crash occurs not because the screen goes off but because of the reinitialization of the network. If the tv loses the connection while the vpn service is running the tv crashes. You may try it by forcing a connection loss turning off the wifi or unplugging the lan cable.
Yeah, I imagined as such at this point. So what it should happen is that the network goes on, the VPN gets the message and tries to switch itself on, doing the switch to the VPN something causes a kernel panic.
Actually I also noticed that the apps I use are now unstable with Android 7.0. I mean, they may force close themselves (it didn't happen in 6.0.1). I really hope Sony won't make us waiting another three months to deliver a new update hopefully fixing this and the USB issues. They are beyong outrageous.
Well, I am not sure anymore this is an issue with the WiFI/network modules. Surprisingly it seems to be something faulty in the digital television services (dtv_svc). This is the failure I get after turning on the television with a VPN app installed and enabled:
--------- beginning of crash 06-19 13:41:16.590 10217 10217 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** 06-19 13:41:16.591 10217 10217 F DEBUG : Build fingerprint: 'Sony/BRAVIA_ATV2_EU/BRAVIA_ATV2:7.0/NRD91N.S36/1.6.0.26.02.1.00:user/release-keys' 06-19 13:41:16.591 10217 10217 F DEBUG : Revision: '0' 06-19 13:41:16.591 10217 10217 F DEBUG : ABI: 'arm' 06-19 13:41:16.591 10217 10217 F DEBUG : pid: 1708, tid: 1887, name: navigator >>> /basic/dtv_svc <<< 06-19 13:41:16.591 10217 10217 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0 06-19 13:41:16.591 10217 10217 F DEBUG : r0 00000000 r1 00000000 r2 ffffffff r3 00000011 06-19 13:41:16.591 10217 10217 F DEBUG : r4 67a3efe8 r5 00000000 r6 a8e8ce0c r7 00000002 06-19 13:41:16.592 10217 10217 F DEBUG : r8 6f5f8948 r9 6f5f88d8 sl ffffffff fp 6f5f88ac 06-19 13:41:16.592 10217 10217 F DEBUG : ip 00000000 sp 6f5f8828 lr a78f83ac pc aad50434 cpsr 200f0010 06-19 13:41:16.989 10217 10217 F DEBUG : 06-19 13:41:16.989 10217 10217 F DEBUG : backtrace: 06-19 13:41:16.990 10217 10217 F DEBUG : #00 pc 000bc434 /linux_rootfs/basic/libdtv_common.so (_net_get_dev_ip+176) 06-19 13:41:16.990 10217 10217 F DEBUG : #01 pc 000c334c /linux_rootfs/basic/libdtv_common.so 06-19 13:41:16.990 10217 10217 F DEBUG : #02 pc 000caa64 /linux_rootfs/basic/libdtv_common.so (x_dhcpc_get_info+68) 06-19 13:41:16.990 10217 10217 F DEBUG : #03 pc 00e50cc4 /linux_rootfs/basic/libmtkapp.so (a_nw_get_crnt_real_ip_info+420) 06-19 13:41:16.990 10217 10217 F DEBUG : #04 pc 00949f80 /linux_rootfs/basic/libmtkapp.so 06-19 13:41:16.990 10217 10217 F DEBUG : #05 pc 00edffc4 /linux_rootfs/basic/libmtkapp.so (nav_brdcst_msg_to_components+296) 06-19 13:41:16.990 10217 10217 F DEBUG : #06 pc 00ee8708 /linux_rootfs/basic/libmtkapp.so 06-19 13:41:16.990 10217 10217 F DEBUG : #07 pc 000309f4 /linux_rootfs/basic/libdtv_common.so 06-19 13:41:16.990 10217 10217 F DEBUG : #08 pc 0002f91c /linux_rootfs/basic/libdtv_common.so 06-19 13:41:16.990 10217 10217 F DEBUG : #09 pc 00017668 /linux_rootfs/basic/libdtv_osai.so (thread_main+76) 06-19 13:41:16.990 10217 10217 F DEBUG : #10 pc 0000be30 /linux_rootfs/basic/libdtv_osai.so (os_drv_thread_main+96) 06-19 13:41:16.990 10217 10217 F DEBUG : #11 pc 00006e80 /linux_rootfs/lib/libpthread-2.18.so 06-19 13:41:16.990 10217 10217 F DEBUG : #12 pc 000ccd7c /linux_rootfs/lib/libc-2.18.so
After that there is a spam in the log of processes dying, like this:
06-19 13:41:20.912 1281 1347 I GRM : Pid(1708) died, will release its resources!!
I also have to add that I am not using an aerial, so I don't have the DTV set up (@Luigi_R do you watch regular television with it?). Maybe after turning on the tv it tries to connect to the internet to refresh the channels informations, it can't connect in an unusual way, and so it fails. Then all other processes follow until the tv reboots.
Now, if only there was a way to completely disable the digital television since I am not using it.. Maybe it would work, I mean at least I could test it.
Sorry for the late reply. Actually since I got the upgrade to Android 7 I have not been able to use vpn service at all even through OpenVPN. Do you have the same problem?
VPN.still works for me on 7.0, but still rebooting if set on boot, or if switched on immediately after waking the TV. Using OpenVPN from F droid.
One solution for those of you who either can't use VPN at all or need it to be on at boot is to share another devices internet. For example, if you have a PC connected by wifi, you can run the VPN on it and share its connection through Ethernet. Silly I know, but then again a lot of stuff with these sony TVs is unexpectedly and unneccesarily silly and buggy and requires half baked solutions it seems.
Well, yeah. I tested a similar workaround. I have the same app in my Mac and I enabled it as a proxy server in there. Then I connected my tv using my Mac as a proxy. But it. is far from being ideal. Also because for my needs (ads blocker. And yes, I want it because it is a pain to load some web pages on television with that ridicolously S. L O W SoC. Just speedtest.net is a nightmare ) the filters don't get all applied.
