I have installed via USB and tested Block This (open source) and Adguard (not together. One per time) on my KD49XD8099 with Android 6.0.1 and they simply worked great! No more annoying ads (yes, I know. Companies don't like it, especially Google, but they are perfectly legal. Also we are allowed by Android itself to install whatever we like).
The only problem is that after turning the TV off (standby) few hours, when I turn it on the television starts rebooting. Uninstalling them the television (and rebooting just in case) Android becomes "stable" again (quoted because I've got reboots even without tampering with special apps). The apps were set to enable the VPN at boot. Not that it should matter, since the reboot happens just putting the tv in standby.
Now, I do understand that an external app, not made specifically for Android TV may not work (but as I wrote they actually do the job they are made for), but if the television/Android reboots there is a (very critical) issue with the OS, not the app. To test the issue the developers just need to install the apps mentioned (again, enabling the VPN at boot).
Hey guys, I have got couple of days ago an update of the system but the issue is still there. Is Sony working in it?. Is there a bug tracker?
I am afraid our best chance is to wait for Android 7. Sony/Mediatek don't seem to do many bug fixing. All major bugs I had before the last update v6.1004 are still there.
Thanks for replying but It is a very annoying bug.How it is possible that no one takes action. I see here bugs related to Amazon and stupid things like that but not this one which leads to a crash of the tv several time a day if the wifi connection is not stable.
PS: by mistake I have terminated the system app streaming channel and I'm not able anymore to restart it. Do you know to do it?
[quote=Quinnicus]Unfortuantely this cannot be listed as a bug[/quote]
If the crash is not caused by the app/s then Sony should care about it since the bug is in the product sold by them. I have tested both Wifi and Ethernet connection and both make the tv rebooting if the tv goes in standby with an active VPN connection.
I will not buy a new router with a VPN support just to workaround a bug in your product.
PS: OpenVPN is in a google play store and it work well on any other android devices
I will buy a new router with a VPN support just to workaround a bug in your product.
The simple fact is that this is not a bug under Sony's Control.
I know that you will disagree on this
Although having a router than supports OpenVPN protocols is a good work-around. I have the Asus DSL-AC68U which can do this.
Quinnicus thanks for replying. I will certainly blame the app if it would be the only one causing the crash but since several apps using the VPN service have similar behavior then I will blame the network manager and/or the os.
As a user, to whom should I report the bug? I bought the TV from Sony then I believe Sony should forward the request to the responsible parties.
Hi there
If its a problem with the app and in this case associated apps that crash when using the OpenVPN app, then my first port of call would be the app developer themselves. I understand this OpenVPN app is available on the Google Play Store on the TV - but I am wondering if it was more developed for the Nvidia Shield instead of an actual TV?
Ok, in simplistic terms:
Indeed, @Anonymous, this is a critical OS issue. An user app, as it is any app from the Play Store, should never cause the OS (or even worse the kernel!) to reboot. Ever.
This is a Denial of Service issue the least, a kernel panic the worst. The userspace doesn't have any permission to kill/restart the whole OS. If that happens it's because an API, called by the user apps (in this case ralated to the VPN) is affected by a very critical, serious bug. And that bug, being in the OS, has been introduced by Sony or Mediatek, so it is a MUST for them to fix it.
Just to give an idea, think if any of the hundreds, if not thousands of users of a super computer had the ability to make the whole system rebooting, just with a bug in their apps. Millions of dollars in service disruption thrown in the toilet. In a much smaller scale this is the same identical concept.
I'm having the same issue as well. Tested on VyprVPN and Torguard. Both forces a reboot if I standby while connected.
The crash seems to come from a mediatek library. I will ask Arne Schwabe, developer of OpenVPN apk to test the app on another AndroidTV (Panasonic or Philips for instance) based on adroid 6. This is the log file from start till the crash:
05-09 22:29:47.184 8623 8623 D com.sony.dtv.demomode.receiver.ScreenStateReceiver: DemoMode receives ACTION_SCREEN_ON intent when AC Off/On
05-09 22:29:47.188 8623 8623 D MtkTvSpecialMode: New class MtkTvSpecialMode
05-09 22:29:47.188 8623 8623 I TVNative: Load libcom_mediatek_twoworlds_tv_jni.so start !
05-09 22:29:47.189 8633 8645 D QuickSetupMgrContentProvider: query()
05-09 22:29:47.194 2915 2990 D ExternalInputProvider: query
05-09 22:29:47.194 2915 2990 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.198 4531 8869 I SonyDTVBrowser_CEB: receive broadcastintent PRE_SCREEN_ON
05-09 22:29:47.199 2915 3524 D ExternalInputProvider: query
05-09 22:29:47.210 4531 4531 I SonyDTVBrowser_CEB: onDestroy
05-09 22:29:47.212 2915 3606 D ExternalInputProvider: query
05-09 22:29:47.212 2915 3606 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.216 2915 2938 D ExternalInputProvider: query
05-09 22:29:47.221 2915 2990 D ExternalInputProvider: query
05-09 22:29:47.221 2915 2990 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.226 2915 3606 D ExternalInputProvider: query
--------- beginning of crash
05-09 22:29:47.228 1208 1208 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
05-09 22:29:47.228 1208 1208 F DEBUG : Build fingerprint: 'Sony/BRAVIA_ATV2_EU/BRAVIA_ATV2:6.0.1/MMB29V.S66/1.6.0.10.04.1.00:user/release-keys'
05-09 22:29:47.228 1208 1208 F DEBUG : Revision: '0'
05-09 22:29:47.228 1208 1208 F DEBUG : ABI: 'arm'
05-09 22:29:47.228 1208 1208 F DEBUG : pid: 1775, tid: 1936, name: navigator >>> /basic/dtv_svc <<<
05-09 22:29:47.229 1208 1208 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0
05-09 22:29:47.231 1716 2546 W NativeCrashListener: Couldn't find ProcessRecord for pid 1775
05-09 22:29:47.231 2915 3524 D ExternalInputProvider: query
05-09 22:29:47.231 2915 3524 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.237 2915 2932 D ExternalInputProvider: query
05-09 22:29:47.242 2915 3606 D ExternalInputProvider: query
05-09 22:29:47.242 2915 3606 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.261 1208 1208 F DEBUG : r0 00000000 r1 78d75230 r2 00000004 r3 00000011
05-09 22:29:47.261 1208 1208 E DEBUG : AM write failed: Broken pipe
05-09 22:29:47.261 1208 1208 F DEBUG : r4 7713eeec r5 00000000 r6 b3e21afc r7 00000002
05-09 22:29:47.261 1208 1208 F DEBUG : r8 7a6f8948 r9 7a6f88d8 sl ffffffff fp 7a6f88ac
05-09 22:29:47.261 1208 1208 F DEBUG : ip 00000000 sp 7a6f8828 lr b28963ac pc b5ca2bd0 cpsr 200f0010
05-09 22:29:47.306 1208 1208 F DEBUG :
05-09 22:29:47.306 1208 1208 F DEBUG : backtrace:
05-09 22:29:47.306 1208 1208 F DEBUG : #00 pc 000bbbd0 /linux_rootfs/basic/libdtv_common.so (_net_get_dev_ip+176)
05-09 22:29:47.306 1208 1208 F DEBUG : #01 pc 000c2ae8 /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306 1208 1208 F DEBUG : #02 pc 000ca200 /linux_rootfs/basic/libdtv_common.so (x_dhcpc_get_info+68)
05-09 22:29:47.306 1208 1208 F DEBUG : #03 pc 0024f768 /linux_rootfs/basic/libmtkapp.so (a_nw_get_crnt_real_ip_info+1148)
05-09 22:29:47.306 1208 1208 F DEBUG : #04 pc 00ad1a60 /linux_rootfs/basic/libmtkapp.so
05-09 22:29:47.306 1208 1208 F DEBUG : #05 pc 002df2b4 /linux_rootfs/basic/libmtkapp.so (nav_brdcst_msg_to_components+296)
05-09 22:29:47.306 1208 1208 F DEBUG : #06 pc 002e79e0 /linux_rootfs/basic/libmtkapp.so
05-09 22:29:47.306 1208 1208 F DEBUG : #07 pc 00030758 /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306 1208 1208 F DEBUG : #08 pc 0002fb14 /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306 1208 1208 F DEBUG : #09 pc 0001759c /linux_rootfs/basic/libdtv_osai.so (thread_main+76)
05-09 22:29:47.306 1208 1208 F DEBUG : #10 pc 0000bdd0 /linux_rootfs/basic/libdtv_osai.so (os_drv_thread_main+96)
05-09 22:29:47.307 1208 1208 F DEBUG : #11 pc 00006e80 /linux_rootfs/lib/libpthread-2.18.so
05-09 22:29:47.307 1208 1208 F DEBUG : #12 pc 000ccd7c /linux_rootfs/lib/libc-2.18.so
05-09 22:29:47.329 8623 8623 D MTKAPI : dtv_svc rpc server confirmed ready.
05-09 22:29:47.338 8623 8623 W libc : pthread_create sched_setscheduler call failed: Operation not permitted
05-09 22:29:47.339 8623 8623 D MTK_MW : c_rpc_reg_mtktvapi_audioinfo_cb_hndlrs <rw_mtktvapi_audioinfo.c: 145>
05-09 22:29:47.339 8623 8623 D MTK_MW : c_rpc_reg_mtktvapi_rating_cb_hndlrs <rw_mtktvapi_rating.c: 443>
05-09 22:29:47.339 8623 8623 D MTK_MW : ####CH LOGO c_rpc_reg_mtktvapi_ch_logo_cb_hndlrs <rw_mtktvapi_df_mngr.c: 166>
05-09 22:29:47.340 8623 8623 D MTKAPI : mtal init result = 0
05-09 22:29:47.340 8623 8623 D MTKAPI : !!!!!!! JNI_OnLoad OK !!!!!!
05-09 22:29:47.340 8623 8623 I TVNative: Load libcom_mediatek_twoworlds_tv_jni.so OK !
05-09 22:29:47.401 1208 1208 W debuggerd: type=1400 audit(0.0:33): avc: denied { read } for name="rmmgr" dev="dm-1" ino=692 scontext=u:r:debuggerd:s0 tcontext=u:object_r:rmmgr_device:s0 tclass=chr_file permissive=0
05-09 22:29:47.412 1716 2465 D WindowManager: KEYCODE_POWER: event.getDeviceId=5, down=false
05-09 22:29:47.416 1208 1208 W debuggerd: type=1400 audit(0.0:34): avc: denied { search } for name="graphics" dev="tmpfs" ino=3060 scontext=u:r:debuggerd:s0 tcontext=u:object_r:graphics_device:s0 tclass=dir permissive=0
05-09 22:29:47.492 2618 2636 V com.sony.dtv.braviasyncservice.utilities: ExternalModuleAccessor.onControlStateChanged() enabled -> true
05-09 22:29:47.492 2618 2636 D com.sony.dtv.braviasyncservice.utilities: ExternalModuleAccessorService changed to isEnabled = true reason = Service wakeup
05-09 22:29:47.493 2618 2636 D com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper()
05-09 22:29:47.493 2618 2636 I com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper.checkDestination:DVB_AEP_T2S2
05-09 22:29:47.493 2618 2636 I com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper.getDestination:14
05-09 22:29:47.493 1716 2504 I HdmiCecController: [S]:<Report Physical Address> src: 0, dst: 15, params: 00 00 00
05-09 22:29:47.494 1716 1716 W HdmiCecLocalDeviceTv: Preferred addres will not be stored for TV
05-09 22:29:47.667 1716 2504 I HdmiCecController: [S]:<Device Vendor Id> src: 0, dst: 15, params: 08 00 46
05-09 22:29:47.837 1716 2504 I HdmiCecController: [S]:<Active Source> src: 0, dst: 15, params: 00 00
05-09 22:29:47.976 1208 1208 W debuggerd: type=1400 audit(0.0:35): avc: denied { read } for name="fusion.0.4" dev="tmpfs" ino=6834 scontext=u:r:debuggerd:s0 tcontext=u:object_r:mt_dtv-svc_tmpfs:s0 tclass=file permissive=0
05-09 22:29:49.146 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:49.152 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:49.228 1208 1208 F DEBUG :
05-09 22:29:49.228 1208 1208 F DEBUG : Tombstone written to: /data/tombstones/tombstone_09
05-09 22:29:49.252 1716 1736 I BootReceiver: Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
05-09 22:29:49.281 8623 8623 D com.sony.dtv.demomode.utils.MtkUtils: isPictureResetModeOff
05-09 22:29:49.300 8623 8623 V com.sony.dtv.demomode.usb.UsbUtils: USBFunction: Auto check function from devices
05-09 22:29:49.301 8623 8623 V com.sony.dtv.demomode.usb.UsbUtils: RuntimePermission: Storage have not granted yet!
05-09 22:29:49.301 8623 8623 D com.sony.dtv.demomode.utils.ShopDemoDataManager: update usbRootPath:null
05-09 22:29:49.301 8623 8623 V com.sony.dtv.demomode.usb.UsbUtils: USBFunction: Set usbFunctionPath=
05-09 22:29:49.301 8623 8623 V com.sony.dtv.demomode.provider.DemoDataUpdater: delete begin
05-09 22:29:49.303 8623 8623 V com.sony.dtv.demomode.utils.ShopDemoDataManager: ACTION_DEMODATA_UNAVAILABLE is sent
05-09 22:29:49.306 8623 8623 D com.sony.dtv.demomode.powerstate.OffRsControlService: onCreate() called
05-09 22:29:49.307 8623 8623 I com.sony.dtv.demomode.powerstate.OffRsControlService: [onStartCommand]: segment=QHL
05-09 22:29:49.307 8623 8623 E com.sony.dtv.demomode.powerstate.OffRsControlService: [onStartCommand]: unsupported segment
05-09 22:29:49.312 8623 8623 D com.sony.dtv.demomode.powerstate.OffRsControlService: onDestroy() called
05-09 22:29:49.317 4980 8875 I DiscoveryApplication: com.sony.dtv.discovery is build-in plugin
05-09 22:29:49.321 8725 8725 I Receiver: Intent { act=com.sony.dtv.demomode.intent.action.DEMODATA_UNAVAILABLE flg=0x10 cmp=com.sony.dtv.sonyshelf/.Receiver }
05-09 22:29:49.325 3064 3064 D IdleTvStandByReceiver: ACTION_PRE_SCREEN_ON received
05-09 22:29:49.327 4980 8875 I PriorityItemListClient: load priority list (shouldRefresh:false forceRefresh:true)
05-09 22:29:49.335 8725 8877 I Invoker : Received action is com.sony.dtv.demomode.intent.action.DEMODATA_UNAVAILABLE !
05-09 22:29:49.344 1716 2594 I ActivityManager: Start proc 8878:com.sony.dtv.enclave.service/u0a6 for content provider com.sony.dtv.enclave.service/.ConfigProvider
05-09 22:29:49.393 8878 8878 W System : ClassLoader referenced unknown path: /system/priv-app/CAL/lib/arm
05-09 22:29:49.405 8878 8878 I EnclaveApplication: onCreate() enter
05-09 22:29:49.407 8878 8878 I EnclaveApplication: Connect to CidUtilService request enter
05-09 22:29:49.415 8878 8878 I EnclaveApplication: isServiceProcess() returns false
05-09 22:29:49.416 8878 8878 I EnclaveApplication: onConnected enter
05-09 22:29:49.419 8878 8889 I ConfigProvider: query()
05-09 22:29:49.419 8878 8878 I EnclaveApplication: mCidService.getCid() bytes length[32]
05-09 22:29:49.420 8878 8878 I UpdateConfigTask: [SetConfig][loadable:true][Did:64]
05-09 22:29:49.433 8878 8892 I UpdateConfigTask: [CurrentConfig][loadable:true][Did:64]
05-09 22:29:49.436 4829 8876 E WhAwareAppOpsCompat: Couldn't initialize instant apps metadata client! Disabling instant apps.
05-09 22:29:49.442 3712 5245 I ECBinderJava: line=100 onTransact() func_name component
05-09 22:29:49.444 3712 3722 I ECBinderJava: line=100 onTransact() func_name component
05-09 22:29:49.708 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:49.708 1232 1308 I GRM : ============================Start==============================
05-09 22:29:49.708 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.708 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:49.708 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:49.708 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.708 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:49.710 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:mheg5_RM_ctrl, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Component Count: 12
05-09 22:29:49.710 1232 1308 I GRM : =============================End===============================
05-09 22:29:49.710 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:mheg5_RM_ctrl
05-09 22:29:49.710 1232 1308 I GRM : ============================Start==============================
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:49.711 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711 1232 1308 I GRM : Component Count: 11
05-09 22:29:49.711 1232 1308 I GRM : =============================End===============================
05-09 22:29:49.711 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:49.897 1716 1716 V DeviceDiscoveryAction: No device is detected.
05-09 22:29:49.897 1716 1716 V DeviceDiscoveryAction: ---------Wrap up Device Discovery:[0]---------
05-09 22:29:49.897 1716 1716 V DeviceDiscoveryAction: --------------------------------------------
05-09 22:29:49.897 1716 1716 V HotPlugDetectionAction: Hot-plug dection started.
05-09 22:29:50.712 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:50.712 1232 1308 I GRM : ============================Start==============================
05-09 22:29:50.712 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:50.712 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:50.712 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:50.713 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713 1232 1308 I GRM : Component Count: 11
05-09 22:29:50.713 1232 1308 I GRM : =============================End===============================
05-09 22:29:50.713 1232 1308 I GRM : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_user_define_share
05-09 22:29:50.713 1232 1308 I GRM : ============================Start==============================
05-09 22:29:50.713 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:50.714 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.715 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:50.715 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:50.715 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.715 1232 1308 I GRM : Component Count: 10
05-09 22:29:50.715 1232 1308 I GRM : =============================End===============================
05-09 22:29:50.715 1232 1308 I GRM : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:50.900 4980 4980 I SPEgetPriorityListCmd: priority list received: 10 items
05-09 22:29:50.900 4980 4980 I PriorityItemListClient: onReceive (the size of priorities : 10)
05-09 22:29:50.900 4980 4980 I DynamicItem: [pos:1]
05-09 22:29:50.900 4980 4980 I DynamicItem: [pos:2]
05-09 22:29:50.900 4980 4980 I DynamicItem: [pos:3]
05-09 22:29:50.900 4980 4980 I DynamicItem: [pos:4]
05-09 22:29:50.900 4980 4980 I DynamicItem: [pos:5]
05-09 22:29:50.901 4980 4980 I DynamicItem: [pos:6]
05-09 22:29:50.901 4980 4980 I DynamicItem: [pos:8]
05-09 22:29:50.901 4980 4980 I DynamicItem: [pos:9]
05-09 22:29:50.901 4980 4980 I DynamicItem: [pos:10]
05-09 22:29:50.901 4980 4980 I DynamicItem: [pos:12]
05-09 22:29:50.901 4980 4980 I PriorityListDataHelper: [pos:1] type:dynamic
05-09 22:29:50.901 4980 4980 I PriorityListDataHelper: [pos:2] type:dynamic
05-09 22:29:50.901 4980 4980 I PriorityListDataHelper: [pos:3] type:dynamic
05-09 22:29:50.901 4980 4980 I PriorityListDataHelper: [pos:4] type:dynamic
05-09 22:29:50.901 4980 4980 I PriorityListDataHelper: [pos:5] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: [pos:6] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: [pos:8] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: [pos:9] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: [pos:10] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: [pos:12] type:dynamic
05-09 22:29:50.902 4980 4980 I PriorityListDataHelper: save item size:10
05-09 22:29:50.902 4980 4980 I PriorityListProvider: onListUpdated list size:10
05-09 22:29:51.230 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:51.236 1716 1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:51.313 8623 8899 V com.sony.dtv.demomode.provider.DemoDataUpdater: update start path=null
05-09 22:29:51.314 8623 8899 V com.sony.dtv.demomode.provider.DemoDataProvider: delete uri=content://com.sony.dtv.demomode.provider.demodata/
05-09 22:29:51.314 8623 8899 D com.sony.dtv.demomode.provider.DemoDataManager: clear
05-09 22:29:51.327 8623 8899 V com.sony.dtv.demomode.provider.DemoDataUpdater: delete End
05-09 22:29:51.715 1232 1308 I GRM : Pid(1775) died, will release its resources!!
05-09 22:29:51.715 1232 1308 I GRM : ============================Start==============================
05-09 22:29:51.715 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.715 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:51.715 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:51.715 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.715 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Resource List-->>>>
05-09 22:29:51.716 1232 1308 I GRM : Resource List--<<<<
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716 1232 1308 I GRM : Component Count: 10
05-09 22:29:51.716 1232 1308 I GRM : =============================End===============================
