I have had ths TV for less than an hour.
I started a manual look for update via the inetrnet and the TV found one. I cant tell you the version.
The TV will now not respond. I have tried a HARD reset via Unplug power, Volume Down and Power buttons on the set side and restored power. Waited for the front light to turn Green and still nothing. The light goes off after 30 seconds with no other feedback. I have waited 30 mins.
Am I alone with this?
Simon
One hour? Probably DOA. Contact the retailer, get it swapped ASAP.
