x
bravia tv last update!
frankkkkkkkkkk
Explorer
Hi there,
I haven't updated my sony bravia 43xe7096 for a year, today it has just popped up and now I can't watch movies.
usb storage -> movie folder -> movie.mp4  and movie.srt (UTF-8) (czech lang)
 is no more working
...it is working but it is same as subtitles (ANSI) before update so
subs example: Ahoj, jak se máš? (Hi, How are you?)
after update  : Ahoj, jak se m|%´
You know what I mean, encoding or what is it is wrong.
What am I, YOU gonna do with that?
2 REPLIES 2
frankkkkkkkkkk
Explorer
ok, I found solution but geez, was it really necessary?
remote control (4 dots button/subtitle)
FONT1 CP1250 the first one which I was always using isn't working
I do have to scroll it up to FONT11 UTF-8 but quite often subs get stuck while scrolling...
I better remove all updates than doing this all the time!
Anonymous
Not applicable
Hi Frank,
Thank you for sharing the workaround to solve this issue.
