Hi folks, this ones destroying me....
Recently purchased the Sony Bravia K-55XR70 after my son decided to use my last TV as a target practice.
Decided to go for this and the Sonos Beam 2nd Generation as well.
Since day one I've had issues with the Bravia Sync with the Sonos Soundbar.
I can control sound intermittently with the Bluetooth remote and other times it says "Adjust Volume On Audio System"
I can only control the Soundbar volume with my app predominantly.
However at certain times it will start working after a restart.
I've just checked the Bravia Sync Settings and none of my connected devices are showing.
What I've noticed is that on the odd occasions the sound control does work, all devices show as connected via Bravia Sync but this rarely happens.
The Bravia Sync device list is currently showing as No HDMI devices found even though my PS5, SKY and Firecube are all connected.
Even when I click enable, nothing is coming up.
Im genuinely stumped and fed up at this point.
All HDMI cables are of good quality etc.
Any help would be greatly appreciated.
Hi, many thanks for the reply.
I have done this procedure on a few occasions.
It seems to work ok for a day or so and then it drops off again.
When it stops working it shows as no HDMI devices found on the Bravia Sync Settings.
Regards
Stephen
