x
Bravia sync seems confused.
SOLVED
profile.country.GB.title
Andy.D
Member
Hi. I received my A95L on Saturday so still setting it up but have met a small problem. I have a kodi player plugged into HDMI 4, but the TV remote doesn't control it - at all. I ended up finding the Bravia Sync device list and according to that the player is connected to HDMI 1, not 4. If I re-plug to input 1 then the remote does indeed control it. If I re-plug back to input 4 then still no good. Is there any way to 'persuade' Bravia Sync that the device really is in 4?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
royabrown2
Hero
@Andy.D
Try having the TV and the Kodi player in standby, or better still powered off, before connecting them together.
Hot-plugging HDMI devices isn’t, strictly, supported, though it often does work; but when it doesn’t, try cold-plugging them instead.
3 REPLIES 3
royabrown2
Hero
@Andy.D
Andy.D
Member
Great - thanks for that. I'll try it tonight.
Andy.D
Member
Brilliant - thank you! I unplugged from the mains and the HDMI cables. Left it for 10 mins and powered back up. Perfect. The remote now controls the box plugged into HDMI 4 (and the list shows it correctly as being plugged in to 4)
Thank you!
