Internet browser stops working and the message "internal erorr" appears . Any help appreciated
Hi there, welcome to the Sony Community
This issue is often resolved by one of the following things:
Try that and see if it works.
Mick
Thanks for the reply , tried firmware upgrade and reset, no joy, suspect a contractural problem
HI there,
If you've tried the following suggestions and the issue has not been resolved, it might be best to get in touch with the support team for further help here.
Cheers,
Sean Mc
