- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
can anyone advise if this model should work with bluetooth headphones ?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the kudo, @stevie_a123
I just edited the post to add an alternative solution if you can’t get it working the ‘Sony way’, so it may be worth you having another look at it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
https://www.sony.co.uk/electronics/support/articles/00159290
XF80 is not on this list
But explore the options there, and see if they throw any light on the issue.
Or this thread discusses an alternative approach, albeit to a slightly different problem, but the solution could work for you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks apprecitae the responses
