Hi all,
I just chucked my LG OLED in for a Bravia 7. I have to admit the picture is close to what im used to. The one thing I need to ask is about preset sound options (ie, movie, game, sport etc). I can't find any, do they exist on this model?
I've looked everywhere.
Thank you.
It doesn’t work like that on these TVs. Instead of canned configurations like those presets, always compromises, you directly adjust the sound parameters that would underlie those, to get exactly the effect you desire, not something artificial.
https://helpguide.sony.net/tv/laep1/v1/en/01-03-09_02.html
Ah I see, thank you for taking the time to answer my question. I appreciate it.
I'm not the best when it comes to sound related anything. I just wanted the sound to have a tad more bass.
I'll have a look at the equaliser options to see if I can tweak it to my liking.
Hey @mrmercury
To increase the bass output of your TV, you can try boosting the low frequencies using the Equalizer in [Settings] — [Display & Sound] — [Picture & Sound]
Start with boosting the first 2 bands (which are the lowest frequency bands in the equalizer) to get more bass
Hi there, thank you. I have done this and sounds a bit better. Sorry I'm not great with sound options.
Thanks again for your help.
