- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
December 2015
December 2015
Hi guys
So i have a a PC with a Geforce 980ti (hdmi 2.0 output), high speed hdmi cable to the TV, but i can only get it outputted at 30fps/30Hz (3840 x 2160).
I notice in the manual this is to be expected directly from a PC:
Corresponding PC input signal
- 3840 x 2160, 67.4 kHz/30 Hz (4K models only)
Since the hdmi inputs are hdmi 2.0 compatible, is there any way i can get this to receive at 50 or 60 fps? How about if i connect the PC through a Sony AV reciever?
(I was thinking STRDN1060 or STRDN860)
Or is this purposely hobbled as its an entry level 4k model.
Thanks
11 REPLIES 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
I Thought the infomation was wrong, thanks for your quick reply mate. i will try what you said.
Alex
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2017
January 2017
Yes i will use my xbox one s HDMI that hould deffently work.
- « Previous
- 1
- 2
- Next »
