Hi All,
I purchased some Skullcandy hesh 2 wireless headphones yesterday, all excited to try these out
on my Sony TV Model - KD-49X8309C
But for some reason it's just not connecting to my tv when I set bluetooth up to search, I have my HTC phone and playstaion pads connected to the TV. I did do a quick search to find that someone had mentioned that Sony TV's don't support bluetooth headphones???
Please tell me this isn't true ? and that something simple as connecting a pair of headphones is possible. If not is there a update coming soon ?? or do I have to spend more money on something to help make it work or is there something in the settings I can change? I also have the soundbar which came with it but can't connect it to that either but unsure if I can tbh.
Thanks in advance
Thanks this app worked for me..
Would it be possible to upload the apk again as the mega link no longer has the file.
You can install free Bluetooth scanner from Google Play. Worked for me.
Thank you so much your post was helpful 😀
