I just bought a KD-43XH8196 TV. I have tried to establish a Bluetooth connection between the TV and the
WH-CH510, but the TV cannot find the headphones. Where's the problem?
Hi @Jaffa74
If you have a look at your TV’s specifications you will see that the Bluetooth Profile required for any audio output by Bluetooth (A2DP) is not provided. However you may find something in the Play Store that will give you a work-a-round. Somebody else may give a recommendation.
Version 4.2;HID (mouse/keyboard connectivity)/HOGP (Low Energy device connectivity)/SPP(Serial Port Profile)
Hi @Jaffa74
